HondaCivicForum.com
-   -   Oil burning - Still scratching my head.. (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/oil-burning-still-scratching-my-head-75292/)
scoob8000 May 5, 2009 05:45 PM
I know, repeat post. But this has still got me scratching my head.
I can live with checking the oil level, but I need to understand the why or how I'm burning it.
New valve seals, 180psi on comression test (dry) all cylinders, car runs great and averages 35-40mpg.
But I'm burning oil. Some trips I use next to none, others I use damn near a half quart in 100 miles! Doesn't seem to be any rhyme or reason to the madness.
  • On acceleration, after around 4000rpm and higher RPM's I see a blue haze in my rear view.
  • There's a big hill by my house with a stop sign at the bottom. No matter how lightly you accelerate from the stop sign, it always produces a nice blue cloud.
  • Breather tube is clean, new PCV valve. Installed a oil seperator in the PCV line. Nothing excessive collecting in there.
  • Usage seems to be lesser with heavier weight oil.
Is it the oil control rings, or the new valve seals? Or am I missing something obvious here?
RonJ May 5, 2009 06:38 PM
Have you inspected the plugs? Are specific cylinders burning oil? Have you tried a cylinder leak down test?
scoob8000 May 6, 2009 03:03 AM
The plugs are all clean looking, no residue and a nice healthy color.
Didn't try the leakdown test because I got what seemed to be pretty good results on the compression test.
Soon as this rain gives in, I'll rent the tester and give it a try.
scoob8000 May 7, 2009 01:43 PM
Still trying to track down the tool. I thought autozone rented them, but they don't. Nobody I know has one either.
A buddy of mine insists it's the oil control rings. Said it's pretty common on Honda's for them to leak.
I'm gonna get some fittings and regulator from lowes tonight and try to make my own tester..
RonJ May 7, 2009 01:58 PM
I'm kind of puzzled by your seemingly contradictory observations that the engine is burning oil but the spark plugs look fine???
gwl May 7, 2009 08:36 PM
I'm guessing you don't have any major oils leaks. Sounds you like have some bad rings.
scoob8000 May 8, 2009 06:01 PM
It's got me too. I got some piece parts together tonight, weather permitting I'll do the leakdown tomorrow and post up the results. I'll try to snap a few pics of the plugs too..
[edit]
Here's the plans I'm basing my leakdown tester on. Instead of gutting a spark plug, I'm using the hose and fittings from my compression tester.
http://www.motorcycleproject.com/mot.../leakdown.html
scoob8000 May 9, 2009 08:53 AM
Well, I don't know how accuracte my tester is but I'm seeing roughly 15% across all four cylinders.
On all 4 cylinders I can hear the leakage going into the crankcase.
I redid my compression test while I was at it and got 178-180 across all four again..
Here are the plugs. Sorry for the low quality, I didn't realize my camera lens was smudged until I was done and back inside. :/
http://post.mach-five.com/posted/1/cyl1.JPG
http://post.mach-five.com/posted/1/cyl2.JPG
http://post.mach-five.com/posted/1/cyl3.JPG
http://post.mach-five.com/posted/1/cyl4.JPG
ef9101 May 9, 2009 09:28 AM
plugs look fine so the rings should be okay as well does it start to rattle after 4000 rpms or when u rev in place does it sometimes back fire it could be a Catalyst converter thats combusted (to old)
ef9101 May 9, 2009 09:30 AM
also is that one plug in the same pics and do they all look lik that? if so are they lik that after cupple days of driving if so then the rings have to be fine wat kinda smok is it a darker black lightish black/grey or a blueish
