Oil Pan...
I got my oil changed from Largo Honda, and they showed me a very big problem. My oil pan drain threads are stripped. They got a sure seal in there now, but my question is:
The oil pan from Honda is $456.70. NAPA has one for my car for $109. Is the NAPA one worth the $347.70 savings?
I would go with a new NAPA over a used junkyard piece anyday. I would laso check out AutoZone because alot of thier parts have lifetime warranties. My question is how did it get stripped? Also, if the head of the bolt was stripped, oil would not leak. If the threads were stripped then it would leak, and you would have seen the drip. What i'm getting at is are you sure it wasn't the dealership that stripped it? Yet another reason why i do my own work...
I bought a used one for $30 and installed it myself. It wasn't that hard. Then I took the money I saved and bought new front rotors and brake pads, a front strut tower bar, and 5 race tires.
Two words: Heli Coil. It would be the cheapest way to fix it and it would work, I know that for a fact. If you chose to replace the pan, go to ebay and you should be able to get one for way lass than $100.
