oil pan gasket. im removing header
Old Mar 16, 2007 | 11:22 AM
POLYTHING's Avatar
Default oil pan gasket. im removing header
2000 civic ex, automatic tranny.
Im changing my oil pan gasket. this is the problem, the lower part of the header and tranny mount are in the way. I can not get to the oil pan bolts (the last 2 on the passenger side) unless i take out the lower header and tranny mount.
i have 2hp 33gal Craftman compressor+air tool @ 90PSI. +10W40 (alot) but the rusted bolts (3) wont come out. WHAT SHOULD I do?
the rest out the bolts are out
Old Mar 16, 2007 | 11:47 AM
mxs's Avatar
mxs
Default RE: oil pan gasket. im removing header
which bolts won't come out?
Old Mar 16, 2007 | 11:51 AM
POLYTHING's Avatar
the one (3 of them) holding the header and the lower header part.
I see in your PHOTO GALLARY, you remove the whole thing down. smart.
you took your pic and marked the bolt position.
[IMG]local://upfiles/11910/E80029BE2AB3432FA9A8E9A8E5AA40E6.jpg[/IMG]
Old Mar 16, 2007 | 11:53 AM
mxs's Avatar
mxs
yeah, I was going to suggest that, it's the easy way to to it. I tried taking the whole header out as one piece and it was near impossible with the A/C in the way.
can the car still run right now? if so, start it and let it run for a while so it gets hot. when it's hot, spray PB Blaster (or another penetrating oil) on the stuck bolts. Let it soak in for a while.
Also, use a 6 point socket, NOT a 12 point. That will give you a better grip, and it will keep you from rounding off the bolts
good luck
Old Mar 16, 2007 | 11:54 AM
Street Sniper's Avatar
Put a socket on there and beat it. Like a poor man's impact.
Old Mar 16, 2007 | 12:04 PM
POLYTHING's Avatar
let s do that.
i was about the use the impact but the slocket wont fit.
Old Mar 16, 2007 | 02:41 PM
POLYTHING's Avatar
well, after lots of PB blaster, only 1 (total of six) bolts came out, the one behind the converter...
after awhile i got tired of the ratchet, i switched to the IMPACT, OMFG, the **** start turning, start strippin [sm=badidea.gif] i had to stop.
just added more more more and more PB blaster...im waiting for them to come loose....stubborn exhaust bolts...
Old Mar 16, 2007 | 02:45 PM
mxs's Avatar
mxs
Are you using a 6 point socket?
Old Mar 16, 2007 | 02:47 PM
POLYTHING's Avatar
ORIGINAL: mxs
when i used the IMPACT gun, yes.
with the ratchet i use 12 pts. I guess i need to buy another 6 pts 14mm for the ratchet
Old Mar 16, 2007 | 03:01 PM
POLYTHING's Avatar
OMG, the impact took OUT 2 more. i guess the ratchet was too weak. however i cant reach the others two, gotta buy an extension...no caro now
it should be easy from now on.
PB blaster actually works! woot
thanks ya SO MUCH!
hopefully i can get this done buy 10 tonight, got a END Of Spring Break Party [sm=bananallama.gif]
