oil pan gasket?.what do u think?
hey guys i have been having trouble with oil leaking for some time now and i have just been adding oil but i decided to try to fix it now...to me it looks like it could just be my oil pan gasket but i have heard it could be somthing worse like the crank seal or somthing (i forget what someoen told me it could be)..i took some pics hopfuly someone can help me..i think its my oilpan gasket..any help or advice is greatly appreciated
[IMG]local://upfiles/406/CC3D4DF735E54490A7938F212960BD18.jpg[/IMG]
[IMG]local://upfiles/406/3B9CCB82656B4709AAF53B60D405C72B.jpg[/IMG]
[IMG]local://upfiles/406/55F8646F1B7E439796EEBDB13789CF46.jpg[/IMG]
ok i did that this morning and they were definatly loose...but i think its still leaking a little bit...i washed the whole underside of the motor and trans so im gunna wait for it to dry up out there and look at it again....is the timing belt cover (bottom half) right behind the crank pully?..i pused against wat seemed to be a plastic cover and oil like gushed out a little does that help a diognosis at all?.,,thanks
i had my car up on ramps and i layed down there and sprayed it with degreaser and let it sit for a few...then took the hose aand blasted the entire underside of the motor, tranny and then used the "shower" part of the nosel and gave it a bath..lol...i did it a couple of times
BTW, its not always a good idea to wash an older motor, a lot of times, the grease is holding the leaks closed, and it can make them leak worse. but thats not a good way to FIX the problem, just a good way to postpone it. i guess im just sayin not to wash it till youre ready to fix any leaks that may arise.
Execut1ve
Feb 6, 2012 07:29 AM
cvcrcr99
Nov 16, 2011 01:55 PM
Speed JUnkyz
Mar 15, 2010 03:34 PM
oilltd
Jun 10, 2008 04:06 PM
oilltd
South West
Jun 10, 2008 03:07 PM
