oil pressure gauge reading 100
Old Feb 28, 2008 | 01:11 PM
00IntegraLS's Avatar
Default oil pressure gauge reading 100
i have an a-pillar oil pressure gauge and usually it reads more down towards 80 and all of the sudden its been reading like 98-100. the needle goes down to 0 when i turn the car off.
Old Feb 28, 2008 | 02:41 PM
Default RE: oil pressure gauge reading 100
well if theweather is colder it could have higher pressure due to the cold fluid. preaty typical. after the cars warmed up real good it should go to normal.
Old Feb 28, 2008 | 02:46 PM
inthezone's Avatar
at least it's not closer to 0 when it's on lol
yeah if the cold front has reached you that could be a reason.
Old Feb 28, 2008 | 03:18 PM
EJ8_Man's Avatar
Ya sounds like the gauge is probably working correctly. How old is the gauge?
Old Feb 28, 2008 | 04:54 PM
polo708's Avatar
once warm your average pressure reading at idle should be close to 50, at WOT would be between 60-70. Either the gauage is shot or something is wrong. Could be a number of things.
Old Feb 28, 2008 | 09:59 PM
gsumano's Avatar
If your using an electric one, make sure the sensor is well mounted. Mine used to give me way off reading all because it was little loose that it would wiggle around the firewall[&:]. After I tighted it better to the firewall it started giving me constant readings.
kylebarbour
Sep 19, 2013 03:07 PM
oilltd
Jun 10, 2008 04:06 PM
lcn584
Apr 8, 2008 07:56 AM
98EKtypeR
Jun 27, 2007 11:22 AM
