overheating
Old Jun 5, 2008 | 05:55 AM
mundy5's Avatar
Default RE: overheating
ORIGINAL: 97blackhonda
i have a 97 honda civic dx d16y7 automatic my car keeps overheating i changed the fan motor,fan relay switch,the thermostat, even the sensor that is in the front of the motor by the distibuter and the fan sometimes comes on, i dont know what else to do[:@]
thanks i bought a new fan switch sensor and now my fan works thanks mk378
Are you telling me that the fan relay switch and the sensor you replaced in your first post is different than the fan switch sensor? how many switches and sensors does this one assembly have? Anyway, I wonder if all the stuff you purchased was unnecessary and the real culprit was the fan switch sensor.
regardless, glad it is now working.
Old Jun 5, 2008 | 06:41 AM
Yes there are 3 electrical devices on a Civic all measuring coolant temperature, for different reasons.
Old Feb 4, 2009 | 10:40 PM
v00d00ppl's Avatar
Originally Posted by mk378
Neither of the 2 sensors screwed into the head under the distributor controls the fan. The one with one wire, toward the back of the engine, drives the temperature gauge on the dashboard (This is called the "coolant temperature SENDER"). The one toward the front of the engine with two wires ("coolant temperature SENSOR") tells the ECU the engine temperature so it will know to run in either warm up or normal mode. The sensor on the thermostat housing is an on-off switch ("coolant temperature SWITCH") that turns on the fan when the water returning from the radiator gets too hot.
thanks this helped me with my fluctuating temperature gauge on my 92 civic.....plus there was an air bubble in the radiator, once we got that out then everything else was good.
Old Feb 6, 2009 | 08:22 AM
v00d00ppl's Avatar
Originally Posted by denice25
Maybe your radiator is the problem, better check on it!
no, coolant was flowing through.....and when i took out the coolant temperature sensor it looked really black and it seemed like whoever worked on my cooling system before didn't let the cap off to release the air bubbles.
trebor_2005
May 19, 2006 01:40 AM
Wooz
Apr 26, 2005 10:04 AM
9toes
Jan 28, 2005 01:43 PM
sonscivic
Jan 4, 2005 06:16 PM
Civic95Blue
Jul 29, 2004 10:09 PM
