Overheating - replaced Rad, Thermostat, Temp sensor, hoses...still overheating
I have replaced my Radiator as the top of it was leaking. I also had the thermostat changed, top hose from rad and also the small hose going into the heater core (?) (into the firewall). Added the coolant (premix). I noticed that when it was cold outside it was fine. Then the weather got warmer and I noticed that I never heard the rad fan kick in. Tested the fan by connecting it to my battery and it comes on. I replaced the temp sensor (TW) and now the fan kicks in when the temp gauge reaches about 1/2 way. But it still rises and I have to crank on my heating in the car to full and then it will go down to the usual about a 1/3 of the way. This is obviuosly not an issue when driving on the highway since the rad gets cooled by the wind. Happens while driving in the city. Also, when I would idle or drive and rev the engine I could hear liquid swooshing sound from the passenger area (although I cannot hear this sound now). Can't figure this out. Would this be a heater core issue? Does the water pump need to be changed? Flush the rad? PLEASE, PLEASE any help/suggestions would help at this point.
try to flush out your engine block. there is a big plug on the front and you take it out and run clean water through it till all the crap comes out, that might help a bit. i don't think the water pump is your problem, because you would probalby have more problems than that. if you have a lot of miles change your timing belt/water pump before they break to save you a lot of cash
I strongly suggest also checking your oil. These are aluminum heads and if you warped it you could be getting warter in your oil gallies. If the oil looks milky (Caramel in color) then you need to absolutely NOT drive or even run it. The aforementioned is of course a worst case scenario. You could also have a problem with your water pump. I would suggest taking it to a RAD shop and let them run a pressure test on it, this will tell you if you have any opens in the system. Most Rad shops will do the pressure test for cheap or free depending on how nice you are.
All are good suggestions. There may be a combustion leak in your cooling system...cracked head, leaky head gasket. Best thing in the world is a leak down test. Once the cylinder is pressurized, pop the radiator cap and check for a rising coolant level or air bubbles in the coolant. If they're present, you have a combustion leak, which can definitely cause the overheating.
comfortablynumb
Oct 8, 2011 04:39 PM
92_hatch
Feb 16, 2011 04:03 AM
chasemclemore
May 26, 2009 07:41 AM
VTECivic95
Jan 31, 2007 12:53 AM
