P04020
Old Dec 17, 2006 | 11:04 AM
cards89's Avatar
Default P04020
I recently purchased a 2004 honda civic ex coupe. The check engine light came on. I took it to a mechanic, he said it was a bad cat. convertor. He replaced. however, when I was driving it home the check engine light came back on. I took it to autozone and they checked the code P04020 bank 1. Does anyone have any suggestions on what the problem is and how to fix. This vehicle was in a flood 1" up on the floor board of the vehicle.
Old Dec 17, 2006 | 12:45 PM
mxs's Avatar
mxs
Default RE: P04020
P0420 is the code that means bad catalytic converter, reset it and see if it doesn't come back on (might take a couple weeks). If it does come back it's probably your second oxygen sensor
Old Dec 17, 2006 | 06:25 PM
cards89's Avatar
Default RE: P04020
mxs,
Thanks for the reply. I had the code reset twice. Once yesterday and again today. It came back on quickly both times, the later only after 5 miles of driving. Is the second O2 sensor in the front at the manifold or else where? How easy is it to change?
Thanks, Robbie
Old Dec 17, 2006 | 07:10 PM
mxs's Avatar
mxs
Default RE: P04020
it's in the cat, just take it back to the place that replaced the cat and have them look at it again.
Old Dec 19, 2006 | 09:50 PM
cards89's Avatar
Default RE: P04020
I took back, the cat is brand new with no problems according to the mechanic. he suggested a vacuum leak or O2 sensors? any help?
