P1456 code and reset
I got the 1456 code for fuel tank pressure. I tightened the gas cap and will be driving the car a lot today.
Will the computer turn off the check engine light if this was the problem, or do I have to reset it myself. If I have to reset it myself, should I drive the car today to build up pressure before resetting?? |
RE: P1456 code and reset
will eventually turn the light off after about 4-5 drive cycles, or get it cleared at autozone etc
before you start the car, turn the key to the accessory position and let it sit for 10-15 seconds.
ORIGINAL: mxs before you start the car, turn the key to the accessory position and let it sit for 10-15 seconds. When I turn the key to the accessory position the light comes on after about 1 second and did not reset. After driving the car a lot today Im thinking that I'll go buy a new gas cap to see if that works. Thanks for the quick reply. |
Ok got the light reset by pulling #13 fuse and have drove a couple of times without the light coming back on.
Thanks everyone for all the help....hope I won't need to ask any more questions. |
