P1456 and P0502
I know what the codes are. I went through a puddle the other day when it rained. These two codes came up. Where should I look first to fix them? I just checked the gas tank cap. The O ring is good and the tank had pressure when I opened it.
Misfire Monitor ok Fuel System Mon ok Comp Component ok Catalyst Mon ok Htd Catalyst n/a Evap System Mon ok Sec Air System n/a A/C Refrig Mon n/a Oxygen Sens Mon ok Oxygen Sens Htr ok EGR System Mon ok FREEZE FRAME DATA MOD $09 ---- TROUB CODE P1456 ABSLT TPS(%) 15.3 ENGINE SPD(RPM)2385 CALC LOAD(%) 40.0 MAP("HG) 11.8 COOLANT(øF) 189 IAT(øF) 81 IGN ADV(DEG) 42.5 ST FTRM1(%) 2.3 LT FTRM1(%) 0.8 VEH SPEED(MPH) 61 FUEL SYS1 CLSD FUEL SYS2 N/A |
Clean and dry the electrical connectors.
I'd image they are dry. It happened a couple weeks ago. Temperatures have been mid 80's - 90's here. Also, can someone please post a picture of where the VSS is located and the canister/purge valve of the EVAP System.
