P1456 and P0502
Old Jul 14, 2010 | 11:39 AM
devolic's Avatar
Default P1456 and P0502
I know what the codes are. I went through a puddle the other day when it rained. These two codes came up. Where should I look first to fix them? I just checked the gas tank cap. The O ring is good and the tank had pressure when I opened it.
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon ok
Htd Catalyst n/a
Evap System Mon ok
Sec Air System n/a
A/C Refrig Mon n/a
Oxygen Sens Mon ok
Oxygen Sens Htr ok
EGR System Mon ok
FREEZE FRAME DATA
MOD $09 ----
TROUB CODE P1456
ABSLT TPS(%) 15.3
ENGINE SPD(RPM)2385
CALC LOAD(%) 40.0
MAP("HG) 11.8
COOLANT(øF) 189
IAT(øF) 81
IGN ADV(DEG) 42.5
ST FTRM1(%) 2.3
LT FTRM1(%) 0.8
VEH SPEED(MPH) 61
FUEL SYS1 CLSD
FUEL SYS2 N/A
Old Jul 14, 2010 | 11:40 AM
Clean and dry the electrical connectors.
Old Jul 14, 2010 | 09:07 PM
devolic's Avatar
I'd image they are dry. It happened a couple weeks ago. Temperatures have been mid 80's - 90's here. Also, can someone please post a picture of where the VSS is located and the canister/purge valve of the EVAP System.
tano001
Apr 25, 2008 03:52 PM
giver13
May 29, 2007 08:46 PM
cernicalo1
Apr 2, 2007 04:13 PM
dasso10
Dec 18, 2006 07:43 PM
ahhsimon
Jun 14, 2006 11:23 PM
