pcv replacement
Old Apr 30, 2006 | 12:47 PM
cdansley's Avatar
Default pcv replacement
i believe i found my pcv valve on my 99 EX while looking from the undercarriage perspective. it appears to be right behind the oil filter. can someone confirm this for me. and i suppose if this is indeed it, the best time to change it is while i'm doing an oil change so that the filter is out of the way?
BTY: Also looking for the air intake sensor...
Old Apr 30, 2006 | 02:20 PM
Street Sniper's Avatar
Default RE: pcv replacement
Do you suspect your pcv is going bad? What you are looking at is the pcv, but it's the valve that you want to replace. It should be a little elbow that goes into a grommet in the inatake manifold. Also, if you are talking abou thte IAT, then it's a small, white, tubular looking thing with a grey plug and it will be in a different location depending on which car you have, but generally toward the back of the manifold.
Looks like...
j_civic_ex
Apr 11, 2006 05:37 PM
johhny b
Apr 7, 2006 04:20 PM
98civiclx
Sep 14, 2005 12:56 PM
nees1212
Aug 5, 2005 10:58 AM
chones2083
May 10, 2005 03:26 PM
