PCV suction check
Old Jan 11, 2007 | 10:32 AM
tuolumne's Avatar
Default PCV suction check
Some of you probably followed by previous post https://www.hondacivicforum.com/m_320822/tm.htm My outstanding question (well, one of many) is this...The PCV valve can only be accessed when the oil filter is removed. I replaced the valve and reaped a 3 mpg increase since. However, I wanted to check the suction on the lines to see if things are clear. I did run a pipe cleaner back in there and it came out clean, but I'm not satisfied. How does one run the car with oil filter moved to get suction? Is there another place I can access the PCV line with the filter installed to check suction? 2000 Civic LX.
Old Jan 11, 2007 | 10:45 AM
Red Hot Rider's Avatar
Default RE: PCV suction check
Find the source of the tube, or possibly "T" the line and cap it.
Old Jan 12, 2007 | 07:22 AM
tuolumne's Avatar
The tube is approximately 4" long. Any access is a one hand job. I can't get a tee in there without taking off the filter again. Maybe next time it's due...
lunger
Jul 10, 2011 02:50 PM
Mahones
Jun 4, 2007 05:04 AM
TheMoogly
Dec 30, 2006 12:22 PM
nees1212
Aug 5, 2005 10:58 AM
chones2083
May 10, 2005 03:26 PM
