PCV Valve and Hose - 94 Honda Civic
Old Nov 28, 2012 | 02:06 PM
housin94's Avatar
Default PCV Valve and Hose - 94 Honda Civic
Hello. I just replace my head gasket, water pump, and timing belt on my 1994 Honda Civic with the help of my step dad. When trying to re-hook the pcv valve hose back, it split in half. I can't figure out how to remove the piece of hose that is still connected to the pcv valve. By attempting to remove the pcv valve I think I cracked the top of it, so that will need replacing also. Does anyone know how to remove the pcv valve also? Thanks
Old Nov 29, 2012 | 09:15 PM
housin94's Avatar
I did some running around today and ended up completing the job.
I got the old PCV valve off by hammering it through the manifold with a old flat head screwdriver. It was my only option because the elbow broke when I tried to pull it out. Got a new PCV valve from Advance ($3) and a new PCV hose from a honda dealership ($8).
A honda tech told me to replace the coupling that connects to the box but instead of spending $4, I cleaned mine out. After removing the old pcv valve, I first connected the hose to the box under the air intake manifold , then I put dish liquid soap on the grommet that is on the hose to make it easier to fit in the manifold hole. I then installed the new PCV valve. I could feel under from the top but I had to remove one bracket, you can get to the PCV hose from the bottom but I couldn't get much leverage. It was a pretty simple job after I removed the old PCV valve.
These pictures are of my old PCV hose split in two, a diagram I edited and a new pcv valve (they are not all the same color). My old PCV hose was dry rotted and very clogged, so I'm glad it split because it needed replaced.
I hope this could help you out. I'm no expert, just work on my car when it breaks down. Its a 94 honda civic, ex coupe with 248,000 miles on it. I got it when it had 214,000 miles. Thanks for looking.
bw1339
May 6, 2009 11:47 PM
sweet_mommy_89
Nov 9, 2008 03:59 PM
reconstyle
Dec 13, 2007 03:24 PM
dazzdillinger
Sep 17, 2007 03:35 AM
frankfurter3
Jun 8, 2006 09:03 PM
