Please Help!! 1990 civic problem!!!!
Old Dec 25, 2011 | 05:24 PM
xn4styxsickx's Avatar
Exclamation Please Help!! 1990 civic problem!!!!
Hello, i am in desperate help! i have read numerous forums up and down with no avail. i have a 1990 4 door civic lx. my problem is this: car idles fine. once i drive my car for about 2 minutes i get a hunting in the idle, loss of power and car wants to die. i have changed the iacv with a new one and checked for vacum leaks. also if my gas tank has less than half a tank of gas and i come to a abrupt stop my car sputters and stalls. also i dont know if this helps but when im driving the car and it starts hunting, if i park the car shut it off for 10 seconds then start it, it will drive fine for another 2 minutes then it will start hunting all over again. please help and please dont tell me to go forum hunting cause i have on numerous forums. any insight will be greatly appreciated. thanks alot!!!!
Old Dec 26, 2011 | 05:19 AM
Yet the CEL is not on? Any codes showing on the ECU?
Old Dec 26, 2011 | 10:30 PM
mpklkj's Avatar
Sounds like you not getting enough fuel.
try putting fuel injector in your gas tank and run the car for awhile.
you might need a new fuel filter.
fuel pump should be fine if it's starting.
Old Jan 9, 2012 | 09:31 AM
Default problem solved
thanks for all the suggestions guys but i found out the problem my fuel pump was completley rusted out and my fuel tank had rust like crazy inside so i just purchased a new pump and tank. thanks for your replies.
kevinhardman92
Nov 21, 2010 07:49 AM
harleykins
Apr 20, 2010 05:37 PM
blk600cc
Apr 14, 2010 01:00 PM
civtec00
Jul 11, 2007 02:59 PM
vamoruso
18
Jul 16, 2005 11:17 PM
