Power Door lock
Does anybody know how to go about replacing the actuators on a 99 ex. My door locks dont work, I can hear a clicking sound coming from somewhere from dash or below it when I move lock/unlock switch. Both fuses have been replaced. Im looking to have remote start/ keyless installed and I was quoted $300 because they would have to put motor(s) in for the locks.
1 Attachment(s)
Your actuators may be fine and the problem lies elswhere. My 00 EX has a keyless remote. Start by checking behind the driver's kick panel for a keyless receiver unit:
Attachment 24165 |
Originally Posted by RonJ
(Post 600662)
http://i267.photobucket.com/albums/i...cture_1580.jpg That is where the clicking is coming from (keyless receiver unit). |
3 Attachment(s)
Using a multimeter to conduct the input tests detailed in the diagrams below should pinpoint the problem.
After you fix the lock problem, just purchase a 99-00 Honda remote and you should be good to go. Attachment 24102 Attachment 24103 Attachment 24104 |
Could someone point me to where the ground (G551) would be :confused: I dont know how to read wiring diagrams so I need to have my hand held :D
a bump for me
Are you asking because the black ground wire lacks continuity?
Asking because I dont have multimeter let alone know how to use one, but have seen on another board that some had same problem and was bad ground. I have the keyless remotes and when I use lock/unlock buttons everything works(lights,horn, dome light) but doors dont lock/unlock.
Originally Posted by bflo99ex
(Post 602063)
will try to find one.
