Power window problem
I have searched around and saw a bunch of window posts, but they did little to answer my questions. I have not worked with windows much so I am a bit out of my experance area. The other day the passenger side front window was wierd going up, but it did go, now it will not move all other windows are working fine. Is there a spefic fuse for the 1 window or does it sound like a bad motor on that one? I tend to use it fairly often so it is becoming a pain in the a$$. I am not sure where to start with finding the issue, please help.
Thanks
BTW if it does not show in my signiture it is a 01 EX 4DR
Thanks
ORIGINAL: wileec
...Is there a specific fuse for the 1 window or does it sound like a bad motor on that one?
ORIGINAL: RonJ
Check whether fuse 22 is blown. Do both driver and passenger switches fail to move the window? If so, it could be the motor or possibly the window regulator.
ORIGINAL: wileec
Have not checked the fuses yet will do that. And yes neither button will operate the window.
ORIGINAL: wileec
OK the fuse 22 was blown, changed it blew right away. Bad motor? regulator? I hate electrical problems[:@]
OK Passenger side switch tests OK as does direct 12v to the motor up and down. Swaped fuse again withe all passanger side disconected and fuse blew instantly. Checked the master switch and the passenger conecters 1,2,3,8 I do not have off continuty 1-3/1-8 does this mean that the master needs to be replaced? Also what is a good source for this kind of part my local bone yard does not have many of this vintage Civic, and Honda is WAY PROUD of their parts $$$$
ORIGINAL: wileec
2) Edit: Yes, the front passenger switch component of the master switch is bad. It might be helpful to verify that the rear switch components instead check out fine in the tests. Try shopping around for a used driver master switch from an online salvage yard.
