prelude civic seats on civic? HELP
Old Mar 8, 2006 | 10:40 PM
ahhsimon's Avatar
Default prelude civic seats on civic? HELP
hey do anyone know or have seen prelude rear seats fit into civics??
and how about the front , can it fit with just prelude rail? or will i need a universal rail
Old Mar 9, 2006 | 05:18 AM
uk civhead's Avatar
Default RE: prelude civic seats on civic? HELP
what civic is it? If its an eg or maybe ek you can get the front ones in. The front mounts on the sub frame will bolt straight up its the back ones that need work, you will need to cut the mounts off the subframe, then match up the mounts on the subframe so they fit the floor pan holes, then weld them nice and strong to the subframe.
Old Mar 9, 2006 | 06:33 AM
Marty's Avatar
The front would require you to use the prelude seat rails and you may need to tap some new holes as I dont know if they are in the same place.
Rear seat = no
Old Mar 9, 2006 | 11:25 AM
natecivic92's Avatar
The prelude has a center console that goes to the backseats which it is notched for.
Old Mar 9, 2006 | 06:58 PM
ahhsimon's Avatar
yeah ,, i only have the fronts prelude seats.. so what im hearing is that the bolts will fit .. but the back of the seat mounts wont .. .because the rails maybe longer or shorter .. and u guys are saying that i would have to cut the mounts .. stretch .. or shorten .. it and then mount the chairs, is there any simpler way ?
Old Oct 31, 2017 | 12:11 AM
Philip Bauyon's Avatar
Just need to swap the rail on outer side and Swap the whole assy on inner side.
xsteinbachx
Nov 16, 2022 10:15 AM
RyanEJ2
Mar 14, 2008 03:00 AM
JFrog
EK Swaps
Sep 10, 2005 12:12 AM
magiconthetire
Jul 3, 2005 05:22 PM
