Problems after swap. Please Help...
Old Apr 14, 2007 | 09:16 PM
Erich73's Avatar
Default Problems after swap. Please Help...
Originally i was going to do my motor swap myself but due to work related commitments i decided to bring it to a local performance shop. I have a 97 civic ex 5spd, and i had a B18c GSR motor installed. the person i bought it from told me it was an OBD2 but it turned out to be a OBD1. The shop sold me the OBD1 to OBD2 cable and installed everything for me. i also had new headers, intake, and catback system installed, along with new spark plugs, wires, and a new cap and rotor.
I finally picked the car up today (shop had it about a week) and drove it home. The shop is about 25 miles from my house. My car didnt feel like it had the power i thought it would, but figured i just had higher expectations. When i pulled in my driveway the check engine light came on. i turned the car off then on again and the light went away.
2 hours later i went out to run to the store. car started great, but as i drove down the road the check engine light came on again and within seconds my speedometer and odometer shut off (tach/gas/temp still worked). i drove back home and checked the wire harness that plugs into the tranny and it was still plugged in. when i restarted my car the check engine light was off.
as i drove down the block again the light came back on and the speedo shut off but i kept driving. as i entered a main road my car bogged down for a second then was fine. i returned home and stalled in my driveway. my car turned back on again and check engine light went off.
the shop opens again on monday so i plan to have my car towed back there. before i go through all of this trouble, does anyone have any suggestions they could give as to why i am having these problems?
Old Apr 14, 2007 | 09:34 PM
Live_4it's Avatar
Default RE: Problems after swap. Please Help...
Did they put both o2 sensors in? OBD2 has two sensors one on the header and one after the cat-converter. OBD1 has only one on the header/manifold.
Old Apr 14, 2007 | 09:50 PM
Erich73's Avatar
i purchased 2 new o2 sensors (as well as a new magnaflow carsound cat with o2 plug input). as far as i know they were both installed. i can see the 1 on my header, i have to get under my car to check the cat o2.
to me it feels like a wiring issue. i have no idea where to begin tolook. could a sensor plug have come unplugged?
~i just realized i clicked on the wrong forum when i posted this message. i meant for this to go in the "Tech Help" forum. my bad.
Old Apr 14, 2007 | 09:56 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
hm...i am not sure what the problem is, i would just take it back in on monday to the shop and tell them what has been going on.
Old Apr 14, 2007 | 11:08 PM
mxs's Avatar
mxs
so the engine is OBD1? are you using a OBD2 ECU or OBD1?
you say the check engine light is coming on, have you pulled the code? if you haven't there's not much more I could say, other than wild guesses. could be any number of things. but knowing what ECU you have, will help.
Old Apr 15, 2007 | 07:59 AM
Erich73's Avatar
its a p72obd1 ecu. im going to readthe instructions on how to pull codes and post what i find later. thanks for the help.
Old Apr 15, 2007 | 08:51 AM
Erich73's Avatar
code 17, VSS (Speed Sense). would this cause my car to stall?i checkedthe connector and it is plugged into my tranny. is there anything else i should check?
**Update. i just rechecked and i am also throwing a code 22 (VTEC pressure valve).
Old Apr 16, 2007 | 09:10 AM
Erich73's Avatar
i found a green/yellow wire that had been stripped back and left exposed in a green plug by my ECU. i checked my helms manual and found this wire to be my VTEC solenoid wire. it must have grounded out against my ECU or chasis. i took the car for a test drive after resetting everything and im still have accelerating issues where the car sputters and feels like its going to stall. my check engine light came back on so i checked for codes again. #8 came up (top dead center sensor).i checked all of the plugs on my distributer and they were all plugged in. could my dist. be bad?
Old Apr 18, 2007 | 06:50 AM
Erich73's Avatar
i got my car back last night. apparently 1 of my hoses was not clampped down correctly causing it to leakanti-freeze onto my VSS plug which was causing it to short out.
hose was reclampped and the connector was cleaned. so far so good!
Old Apr 18, 2007 | 10:47 AM
blackmetal619's Avatar
is it as fast as you hoped now?
