Produces cold air when it should be hot air.
Old Feb 8, 2007 | 07:00 AM
dregular's Avatar
Default Produces cold air when it should be hot air.
I have a 03 civic. When I am traveling on the highway my car will produce good heat. When I stop or even slow down it begins to blow cold air and the temp. gage is in its normal position. Can you tell me why its producing cold air when it should be hot air. Thanks.
Old Feb 8, 2007 | 06:56 PM
big_boy1883's Avatar
Default RE: Produces cold air when it should be hot air.
I am also having the same issue with my 03 civic. Any ideas??????
Old Feb 8, 2007 | 07:01 PM
Tater's Avatar
possibly not enough coolant going through your heater core to heat it up enough to your desired level since it is so cold out. bad thermostat?
Old Feb 8, 2007 | 07:09 PM
Misha's Avatar
If your engine is K20, I would say most probably it's the belt. Check and tighten if too loose.
If not - partially blocked heater core would be my second best guess.
Old Feb 8, 2007 | 07:10 PM
Misha's Avatar
Tater, thermostat has nothing to do with heater circuit, get your car first, then try to advise others.
Old Feb 8, 2007 | 07:28 PM
Stumasters's Avatar
Is the 03 heater computer, or manual cable controlled?
Old Feb 9, 2007 | 08:17 AM
fglaustin's Avatar
the thermostat closes off to allow the water in the block to heat up and then opens at a certain temp to allow the water to move into the heater core. if the thermostat sticks open, then the water does not heat up enough to give hot air.
to the both of you, take the thermostat out and check in a pan of boiling water
Old Feb 9, 2007 | 09:37 AM
forget checken the dam thing... just replace it with a hoter thermostat.... and when spring comes change it back to stock temp thermostat....
ive always got to do that with my truck... in the winter its just hard as hell to heat up!
but if ya dont want to do all of that just keep your air on recirculate....
Couchpotato226
Sep 22, 2014 01:24 PM
Jackdigsdirt
Jun 13, 2011 05:57 PM
general23cmp
Dec 20, 2008 10:43 PM
vtec02
Apr 30, 2007 11:53 AM
carlover
Jul 25, 2005 10:13 PM
