Pulsating lights (interior & exterior)
Old Oct 20, 2007 | 11:26 AM
Default RE: Pulsating lights (interior & exterior)
actualy dimming can hurt your amplifier and subs! depending on the voltage drop.... for instance i had a Orion D2500, and with the voltage dipping under 11volts the amplifier would fry! went thru 2 of them that way before upgrading my alternator for a highoutput unit and then never fried anymore amps
but if you want more power for your System.... then buy a highoutput alternator. i think like 150 or 160amps is the highest you can get for a civic.... but still TWICE as good as the pathetic 70amp stock alternator!!!!!!
ill advise upgrading to a stronger alternator if your battery is in good condition.
the battery just holds power... the alternator MAKES power.... id buy a highoutput alt before ya buy a second battery cause tho it may sound VERY EASY to to just slap another battery in you HAVE TO THINK ABOUT A POSIBLE SHORT POSIBILITY! this means instead of using a SIMPLE one main fuse you need 2 if not 3 main fuses!
it can get expensive with the small things..
jimijam
Jan 23, 2012 05:17 PM
Pigwatcher3
Sep 24, 2010 04:06 AM
MaximusFunk
Jan 26, 2010 04:46 PM
Doug8N
Dec 17, 2007 07:18 AM
ELECTRON BLUE 2000
Apr 10, 2007 03:53 PM
