question
Old Jun 16, 2005 | 01:43 PM
99civicsohc's Avatar
Default question
I have a 99 ex with cam pulley valves, springs, bigger injectors, vafc2, cold air intake, header back exhaust. I was just wondering if anybody knew some basic settings I could star with for tuning the vafc. I got it pretty close but it still isn't right my gas mileage is pretty bad.
Old Jun 16, 2005 | 06:52 PM
AOL.COM's Avatar
Default RE: question
what kind of mileage are u gettin ? ----honda tweeks their motors for good mileage so the more mods u do the less mpg you will get ---but in sure u got more plenty of power----but i would think the big injectors have something to do with it
Old Jun 16, 2005 | 09:18 PM
sacicons's Avatar
start by taking out 1-2 percent of the fuel. but youre not going to make any power with that thing without a dyno or at least a wideband O2.
Old Jun 17, 2005 | 10:06 AM
polo708's Avatar
exactly... You will need a wideband o2 sensor... you can buy one for around $300 or get a few Dyno pulls in for about $50 a pop.
Run you rcar and see what the a/f ratio is at... Ideal when you are at wide open throttle is about 12.5:1. So it sounds like you are running rich (too much fuel). The reading should be lower than 12-13 ish (probably something like 10-11:1) If this is the case then take away fuel (lean it out). Keep experimenting until you are where you want to be.
If you buy a wideband o2 sensor then you can do all the test you want... on the road.
most cases:
Peak HP is reached at 12:5:1 a/f ratio
Peak torque is reached at 13.8:1 a/f ratio
Daniel Arrey
Jul 31, 2014 03:15 PM
thakid
Dec 11, 2006 08:49 PM
