Question
Old Feb 9, 2010 | 03:42 AM
SkinnyMRH's Avatar
Default Question
Sometimes when I'm driving at night my headlights and cluster brighten up drastically then go back to their normal brightness a few times and then back to normal. I need to know if that it's something serious like my alternator, battery or something electrical. I have a 98 Civic hatch.
Old Feb 9, 2010 | 07:08 AM
First check whether 7.5A fuse 15 under the dash is blown. If the fuse is fine, then drive your car to an auto parts store to have the alternator tested.
Old Feb 9, 2010 | 02:06 PM
mundy5's Avatar
+1 on the alternator especially if it is original.
Old Feb 10, 2010 | 03:05 AM
SkinnyMRH's Avatar
thanks i asked a coupe of guys I know who know cars and they said that it might be a solenoid in the alternator. Can't really get that fixed, i'll look into this some more.
Old Feb 10, 2010 | 06:14 AM
mundy5's Avatar
get a reman one from a parts store. they come with lifetime warranty or make sure it does. Mine did.
Old Feb 10, 2010 | 06:26 AM
Do yourself a favor by first properly checking fuse 15. Otherwise, you might replace your alternator for no reason.
Old Feb 11, 2010 | 03:57 AM
SkinnyMRH's Avatar
Alright I'll take a look at it.
Old Feb 11, 2010 | 04:53 AM
i say check your grounds also, poor connection can cause your lights to do that.
Old Jul 8, 2010 | 04:55 PM
SkinnyMRH's Avatar
Well my car is currently dead. Battery died on my way to work two weeks ago, getting a new alternator and battery soon. HOPEFULLY this will be the cure to that little problem.
Old Jul 8, 2010 | 05:04 PM
Sounds like classic fuse 15 syndrome. Did you ever check it? If the fuse is blown (due to wires behind the engine shorting out) the alternator will not power up and charge the battery properly.
