questions for sacs
Old Mar 23, 2005 | 12:39 PM
copyguy6188's Avatar
Default questions for sacs
sacs, what are you talking about when you said something about the timing at 14 BTCD. Not familiar with that. also, being the the block is decked at 20 thousands, how much HP do you think i will be gaining, and no, i am not doing the turbo anymore. Man, I really appreciate all the help and suggestions you have given me.
Old Mar 23, 2005 | 12:55 PM
Remmy's Avatar
Default RE: questions for sacs
Not trying to flame you but, its kinda against forum rules to go out and direct a question for another member, you should PM him instead.
Old Mar 23, 2005 | 02:00 PM
sorry rem. As you can see, i'm a newby. Didn't know, and i will not do it again. sorry bout that. i'll see if i can figure out how to PM somebody. Thanks for the heads up!
Old Mar 23, 2005 | 02:17 PM
Remmy's Avatar
Its all good. Find sacicons' name in the directory to pull up his file. If you look around you will see a "PM" buttun in blue.
Old Mar 23, 2005 | 02:23 PM
Remmy's Avatar
never mind its not in blue but here is a snapshot I took for you, I circled it also... this is the page that you get when you click on somebodies member name in the forum... like I did to mine. And dont worry about being a n00b. No one is judged here by there greenieness. Besides... everybody was a n00b before at one point in time.
[IMG]local://upfiles/1537/CFC38476FB364549A64B94C2621DA81F.jpg[/IMG]
Old Mar 23, 2005 | 10:42 PM
sacicons's Avatar
i might as well answer it, seeing as how the answer will have some info others might not know. 14* BTDC means fourteen degrees before top dead center. a degree is 1/360th of a rotation (the circle of the rotation being 360 degrees) of the crankshaft. so that means that the spark plugs will fire when the piston is 14 degrees away from the highest point it will reach (Top Dead Center) usually the ignition timing on a honda is around 16-18* BTDC, but with higher compression, you need to retard it, richen the fuel mixture, or run better fuel, as it being too advanced (bigger number) will cause detonation. the great thing about this, is that you can fill the tank with 104 octane race gas on raceday, advance the timing to 16*, and gain about 5-15 horses. your gains from the decked head should be around 2-3 pecent, doesnt sound like a lot, but it will also increase the efficiency of your engine, so you could get a little better mileage, and with some bigger cams, you will get even more gains than you would at stock CR.
Old Mar 24, 2005 | 10:44 AM
thanks for the input sacs. Very helpful.
Old Mar 25, 2005 | 01:29 PM
2000Ex's Avatar
ORIGINAL: sacicons
THis guy knows everything
Old Mar 25, 2005 | 10:32 PM
sacicons's Avatar
no, i just know enough to act like i do.
Old Mar 26, 2005 | 03:07 PM
JW2501's Avatar
wow! you never cease to amaze me sacs. By the way, where did "sacicons" come from?
