Quick question on motor mount inserts
Old Jul 10, 2008 | 08:53 AM
psychocarne's Avatar
Default Quick question on motor mount inserts
I have a 92 civic hatch with a gsr swap. Im about to pull the motor to do the timing belt, clutch, and intake mani gasket. I figured while its out i should pick up some of them ES motor mount inserts. Just wondering if i get the integra ones will they work with my setup? Im sure someone has experiece here. And i did search .
Thanks guys
Old Jul 13, 2008 | 12:38 PM
Default RE: Quick question on motor mount inserts
Bump anyone know?
Old Jul 13, 2008 | 03:51 PM
sacicons's Avatar
i used the 99-00 si ones in mine, and i had to trim them a bit, but they fit fine. well, the front 2 anyway. i never did the back one, but ive heard from a few people that it makes it vibrate way more than just the front 2. but the teg ones should work, the mounts on your car are probably from a teg anyway.
Old Jul 13, 2008 | 04:09 PM
Thanks man, the mounts are a mix of civic/integra mounts so thats why i wasnt sure. I think the teg ones will work though just tryin to double check before i order.
Old Jul 13, 2008 | 04:24 PM
sacicons's Avatar
yeah, its been a long time, but i remember i just had to trim some little tabs on the mount, and they fit. easy enough.
Si Jonny
Engine and Internals
Apr 13, 2008 03:37 PM
PREKGSR
Jan 29, 2008 05:18 PM
bp4131017
Aug 2, 2007 05:34 PM
01CivicEX
Mar 8, 2007 08:00 AM
windcalmer
Jan 16, 2007 04:13 PM
