R & R rear brakes
Old Mar 7, 2011 | 08:26 PM
davelew's Avatar
Default R & R rear brakes
I need to replace the brakes on my 06 Civic. The clips are occasionally rubbing against the rotors and started to chirp/squeak. Are there anything that I need to be aware of when redoing the rear brakes since they are tied in with the parking brakes?
I changed the front pads and turned the rotors last month and it was pretty straight forward. The original front pads lasted 63k miles.
Thanks for any advice.
Old Mar 7, 2011 | 09:18 PM
209Chris's Avatar
On most vehicles with rear disc brakes u need a tool to turn the piston into the caliper u can tell if this one is that way by looking at piston face if it has sum notches or holes in it u will need this tool reason for the turning piston is this is the self adjusting nature of the parking brake
Old Mar 9, 2011 | 09:42 PM
davelew's Avatar
Is this a must-have tool or can one improvise to replace the rear pads? I take it you don't just compress the piston back into the housing with a C-clamp and block of wood as with the front brakes?
This will be my first time doing rear disc brakes.
Old Mar 11, 2011 | 09:33 PM
209Chris's Avatar
Sorry bro dunno why it didnt pop up u commented till now and no ive made due with needle nose pliers before its.jus.a.pain I believe.the tool cost less.then 5 bucks just goes on a 3/8ths.ratchet
Old Mar 11, 2011 | 09:35 PM
209Chris's Avatar
And the tool is just a cube eavh side has its own pattern suppose to work on all cars but who knows
carid
Mar 18, 2015 04:39 AM
ultrarevvin1
UltraRev
Jan 31, 2014 07:42 AM
jonsaidthat
May 30, 2010 09:30 PM
ahhsimon
Jun 14, 2006 09:52 AM
faceless_civic
Nov 17, 2004 10:19 PM
