Rattling A/C Compressor?
Hi All, First post. My trusty 97 hatchback (bought it new,now has 126k) has a rattling grinding noise coming from the a/c compressor. I removed the belt and the noise disappeared, so I know the compressor or it's clutch is the cause. The noise gets a bit quieter when the a/c is turned on. How can I tell if the noise is due to a bad a/c clutch or if the compressor itself is bad? Is there a bearing in the clutch and one in the compressor? The a/c works fine, it just has gotten much noisier. The belt tensioner pulley seems ok. Any help is appreciated!
Rob
Rob
Sounds like you have a bad rotor pulley bearing (see picture below and in next post), which is part of the clutch.
[IMG]local://upfiles/25538/F4DA3F067FCF4B519FC32CC8071084C0.jpg[/IMG]
This picture shows a disassembled view of the compressor. Both the compressor proper and clutch rotor pulley have bearings. If you plan to overhaul the clutch, I can also post those instructions.
[IMG]local://upfiles/25538/A9787199C10B408F877F0C289536C856.jpg[/IMG]
The next two posts are instructions for the clutch overhaul (overhaul #1 and #2).
Subsequent posts will show how to remove and re-install the compressor.
[IMG]local://upfiles/25538/827805D2280F4CD79244A5C8CCDF176D.jpg[/IMG]
The next four posts cover compressor removal/installation (#1 & #2), evacuation (#3), and charging (#4).
[IMG]local://upfiles/25538/BBE333D9077F40E9A844CA7C964B6F7F.jpg[/IMG]
