HondaCivicForum.com
-   -   rear axle removal? (bended) (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/rear-axle-removal-bended-81175/)
mdemers Feb 25, 2010 02:30 PM
Hi All!
Anyone knows if I need to remove the trailing arm in order to get that little rear axle out?
Brief: The person that used to have it banged it on a side walk (he lost control in the snow and landed on a high beamed side walk). The wheel was bended. So when I removed the rear bearing, I could see that the shaft (or axle) is bended...
Thanks in advance!
...Mart
StifflersMom Feb 25, 2010 02:43 PM
What rear axle? Lower control arm? Hub?
mdemers Feb 25, 2010 02:56 PM
The hub. Basically, its the shaft that bolts the bearing(32mm nut).
Removed dust cap, removed the 32mm bolt, removed bearing and I see the shaft (not sure its the right term) is crooked. Want to replace it...
StifflersMom Feb 25, 2010 03:04 PM
Can you take a picture? It's been a couple of years since I've been in that area of a civic.
mdemers Feb 25, 2010 03:11 PM
sure..hold on...and thanks!
mdemers Feb 25, 2010 03:20 PM
picture to big. you can find it here:http://www.site.uottawa.ca/~mdemers/civic/P1000843.JPG
Hard to see but it is bended...
What do you think? Do I need to remove the trailing arm or I can remove only the shaft?
WellFedHobo Feb 25, 2010 03:52 PM
Nasty looking knuckle.
There is no rear axle. It's an independent coil suspension setup. What you are looking at is just the thing that holds the knuckle together.
There are several torx bolts (star shaped) on the back side of it. I believe there are 4. Remove those and the whole knuckle comes off. It's MUCH easier if you just pull the whole trailing arm. That way, you can see the 4 torx bolts clearly. It's not as big a deal as you would think to pull the trailing arm off. You probably had a harder time taking the hub apart.
mdemers Feb 25, 2010 04:23 PM
Well I'll be a son of a gun!
Alrighty then, I hope I will be able to remove the hand brake cable & brake line (tried it, rusty and seized!). Or maybe I won't need to, since that I never did that before, I will see and learn :)
Rebuilded a Blazer 95 last summer, so at least I know a little bit.
Thanks for the hand !
WellFedHobo Feb 25, 2010 04:33 PM
Give me a minute and I'll get you a picture of the torx bolt locations.
http://img.photobucket.com/albums/v1...Honda/torx.jpg
There are 3 or 4, I don't remember. But there are round holes in the metal. You'll see them. Be sure to have a jack stand under the car when you look under it. Don't use the scissor jack from the trunk.
RonJ Feb 25, 2010 05:50 PM
1 Attachment(s)
What's bent is called the spindle, but you need to replace the entire trailing arm to fix.
Attachment 13815
