rear defrost
You could try a couple of things here. If you have access to a voltmeter you could check each wire for 6volts. If the voltage is missing then the wire maybe broken. To repair the wire you could use silver conductive paint, available at most parts supply stores. Easiest way is to use a small brush and scotch tape over the damage. Cut a small hole in the tape and let the paint dry for 30 minutes before removing the tape and then retest. Hope this helps
badkitty10
Feb 14, 2010 04:27 AM
kdvanstrum@earthlink.net
Mar 27, 2009 05:42 AM
