Rear Defrost Timer
Old Jan 29, 2010 | 05:58 AM
crazyone64's Avatar
Default Rear Defrost Timer
Hi
I recently bought a car starter but the 01 Civic LX Rear Defrost stays on for a max of 7 minutes.
Due to the extreme weather in the winter, I'd like to increase this closer to 15minutes.
Can this be done ?
Old Jan 29, 2010 | 06:03 AM
Dipsetcivic117's Avatar
yea. just hit the button again. lol.
but i dont think you can reset the amount of mintutes the defroster stays on for.
Old Jan 29, 2010 | 07:12 AM
If it's like older models, the timer is in the button. I think it is a simple resistor-capacitor circuit that could be modified by changing the resistor or capacitor. Or it should also work to just pull the control wire to ground which will close the relay under the hood and energize the defogger. Maybe your starter has an aux output of some sort that can be programmed to do that.
The reason it has a timer is that the defogger puts a rather heavy load on the alternator.
badkitty10
Feb 14, 2010 04:27 AM
kdvanstrum@earthlink.net
Mar 27, 2009 05:42 AM
petrosorr
Jan 12, 2007 08:14 PM
1stgen
Mar 23, 2006 10:14 PM
brolo
Nov 19, 2005 06:16 AM
