relatively low mile '02 with squeaky clutch
Old Jun 21, 2008 | 08:12 AM
mixwhit's Avatar
Default relatively low mile '02 with squeaky clutch
'02 EX w/ 47k miles. engine off (or on), press in the clutch pedal and I get a squeaky noise. i figured it would just be a linkage joint so had the spouse press the pedal while i listened. the sound appears to come from the front right part of the engine. i figured out it's a hydraulic clutch and it looks like it enters at this point. I see a large rubber boot. is the culprit under this boot, and is it safe to pull it back? i think i might wait until the next oil change so i can get at this from the bottom (it's a tight fit from the top).
thanks
Old Jun 23, 2008 | 08:21 AM
JimBlake's Avatar
Default RE: relatively low mile '02 with squeaky clutch
Pull the rubber boot open & have a look. The piston rod from theslave cylinder pushes against a ball/socket thing & you can grease that.
Theres another ball/socket where the throw-out lever hinges, you might not be able to reach that unless you remove the tranny.
The last thing is the throw-out bearing sliding in & out. If thats the noise you really do have to remove the tranny.
thatguy
Apr 1, 2014 03:32 PM
WhiteRabbit1021
Jul 15, 2007 09:33 PM
dooka4u4
Jul 18, 2006 02:51 PM
no1rc3ur
May 14, 2006 09:54 PM
Spartan21
Oct 14, 2005 06:50 PM
