Removing rear door inner panel
The child lock is on, and the door handle is broken. I need to be able to remove the inner door panel for the rear driver side door, which is stuck in closed position to replace the door handle.
If I was able to get the door to open, then I can google for the rest of the instructions.
Any idea how?
Any idea how?
Your kinda screwed there but first try opening the front door and see if you can get to the hinges for the back door. If you can take the bolts out and open the door some to pop the door panel back some to engage the door handle. Might work if not rip the door panel off, pop the door open and buy a new panel....Good luck
darren509
Nov 21, 2011 08:15 AM
dukevalentino
Feb 20, 2011 06:30 AM
addiction2bass
Mar 10, 2008 02:04 PM
