ricey exhaust :/ ?
Old Nov 13, 2011 | 06:46 PM
Ramyswar's Avatar
Default ricey exhaust :/ ?
I have a 02 civic dx. The cat is connected to the exhaust manifold. I just put a header on it so I have no cat, and its making an extremely ricey sound. I was wondering if it is because I don't have a cat, or could it be that the exhaust is leaking where the end of the header connects to the exhaust pipe?
Also, I just used the old exhaust manifold gasket, is that a real issue?
Any insight would be helpful, thank you.
P.S. the header isn't for gaining 100bhp, I know I'm driving a Honda civic, my manifold just cracked down the middle.
Old Nov 13, 2011 | 07:30 PM
You can check for leaks by temporarily blocking the tailpipe with the engine idling. It should just quietly build up pressure. If there's a leak, exhaust will hiss out of the leak.
A cat converter has a considerable quieting effect as well as of course getting rid of pollution. I would suggest installing an aftermarket unit (make sure it's a real converter, not the ebay ones that are just an empty pipe) after the header.
Old Nov 13, 2011 | 07:59 PM
Ramyswar's Avatar
Ok, thanks. I'll put a cat on and see how it goes
drbyers
Dec 12, 2006 11:09 AM
B!@ckBoYwiTaC!v!c
Dec 5, 2006 12:32 PM
jimbolion
Oct 8, 2006 03:01 AM
Mr Mobsta Man
Sep 19, 2006 11:33 PM
94CivicB18
Aug 27, 2006 04:08 AM
