rough idle
Old Feb 15, 2008 | 01:25 PM
jayh1813's Avatar
Default rough idle
i swapped motors for my 94. i put in a stock d15b7. i got it running and took it out for a ride today and i was letting it run in my drive way for a little bit and it began to idle up and down up and down. i checked all fluids and everything is good. i think it may be a sensor... maybe the TPS? any other ideas???
Old Feb 15, 2008 | 01:34 PM
Default RE: rough idle
Is the CEL ON?
If not, this symptom can be caused by a dirty IACV, bubbles in the coolant system, or an intake air or vacuum leak.
Old Feb 15, 2008 | 02:43 PM
jayh1813's Avatar
the CEL came on for a few minutes until i shut if off then i never came back on. the speedo also doesnt work anymore it just flickers up and down sometimes. i checked the vaccuum lines and air box lines i didnt notice anything really but i will check again tomorrow.
Old Feb 15, 2008 | 04:10 PM
Retrieve the CEL code as described here:
http://www.honda-tech.com/zerothread/1901557
Clear the code and, if the CEL returns, retrieve again to determine if it is the same. The speedometer problem is possibly a faulty Vehicle Speed Sensor, which may be confirmed by the CEL code that you retrieve.
For the idle problem, try bleeding the coolant system:
Old Feb 15, 2008 | 09:46 PM
jayh1813's Avatar
ok i will try that 1st and see what happens. thanks i will let you know the results.
Old Feb 16, 2008 | 06:49 AM
jayh1813's Avatar
ok so i went out first thing. it ran strong and no problems for a while. i took it out for a ride and the CEL came on. so i turned around back to my house. i restarted the car and the CEL was gone. then i came back during my next ride. and i restarted the car it it was gone. and it seems the car only idles up and down when the CEL is on. but if i turn the car off and on the idle levels out. i think it may be the Vehicle speed sensor. any other sugguestions
Old Feb 16, 2008 | 07:04 AM
Retrieve the CEL code as detailed in the link of my earlier post. Even if the CEL is OFF, the code is stored in the ECU.
Old Feb 16, 2008 | 08:43 AM
jayh1813's Avatar
its the vehicle speed sensor. im going to make sure i plugged it in right. i got a 17 on the code from the CEL check. thanks again for everything
Old Feb 16, 2008 | 09:47 AM
jayh1813's Avatar
is this what i need or is there a whole other assemly to it?
http://cgi.ebay.com/ebaymotors/HONDA-ACCORD-CIVIC-ODYSSEY-VEHICLE-SPEED-SENSOR- 92-97_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247Q QcategoryZ46104QQihZ002QQitemZ120213316849QQrdZ1QQ sspagenameZWD1V
Old Feb 16, 2008 | 10:08 AM
First verify that the speed sensor is malfunctioning:
