rubbing noise when accelerating on 94 civic
Sounds like the noise is coming from the rear passenger wheel. Like i said the sound changes as you accelerate. Its like a rubbing, humming sound. Its not a clunking sound. Would it be a brake or a wheel bearing problem? bearings hard to replace?
Thanks so much!
Thanks so much!
Sounds like the rear brake may be dragging. Put the rear end on jacks and then try to spin the wheel by hand. Next pull the wheel off to inspect. You may need to loosen the brake mechanism using the star adjuster to get the drum off.
ORIGINAL: brian400ex
it has disc brakes on the rear
Is it difficult to spin the wheel by hand? Pull the wheel off and check whether the brake caliper is stuck and dragging. If the brakes are fine, then it might be the bearing.
Elizabeth S
Oct 2, 2012 12:03 PM
civic0909
Apr 5, 2012 08:41 AM
98civicftw
Jul 15, 2010 03:21 AM
syncro
Aug 16, 2007 01:27 PM
