Seat Swaps
Old Nov 23, 2008 | 04:05 PM
burnindesirez02's Avatar
Default Seat Swaps
So i got 90 CRX SI seats and i want to put them in my 93 Civic ex. Does anybody have any ideas on whether or not the brackets are interchangeable?
Old Nov 23, 2008 | 04:49 PM
probably not BUT one way to find out
Old Nov 24, 2008 | 07:50 AM
you don't think they are interchangeable? So if not can you buy conversion kits or something of that sort?
Old Nov 24, 2008 | 08:02 AM
seanflaboy's Avatar
u have to change the brackets
Old Nov 24, 2008 | 11:00 AM
Is it only the three gold bolts on the bottom?
Old Nov 24, 2008 | 11:13 AM
the seat rails should swap right out. Two (possibly 3 - some have 2, some have 3) bolts on the side without the seat belt buckle (all 3 holding the seat rail to the seat bottom), and then 3 bolts on the side with the seat belt buckle. (one bolt holding the side of the seat-back cushion to the seat rail bracket, and 2 holding the seat bottom to the seat rail)
They may even bolt right in without swapping rails... i'm not sure, so try that first. (just put them in the car and see if the bolt holes line up)
Old Nov 24, 2008 | 11:27 AM
Hailchristian's Avatar
Well...i have read a lot about this, but the opposite. Such as EG or EK seats in a crx.
what you have to do is a seat pan swap...
check this out
http://www.honda-tech.com/showthread.php?t=2189540
Old Nov 24, 2008 | 11:43 AM
check this out
Damn, I thought about that but wasn't sure. I had to do that in my Del Sol with my GSR seats. Needless to say, it was hell... turned out well though.
The reason for this is because the CRX and Del Sol Seats are much lower than the Civic or Integra seats and when you put the CRX or Del Sol seats in a Civic or Integra you end up sitting real low. If you do the opposite, you end up with your head through the roof.
But really I think you should be fine without swapping seat pans. Especially if you're tall. The CRX seats will just sit a little lower than the Civic seats did, but that shouldn't be a problem really because your going lower in the car, not higher. It becomes a problem when you put Civic or Integra seats in a CRX or Del Sol because then you end up sitting uncomfortably high.
Though, Hailchristian may be trying to point out that you have to swap seat pans because of bolt hole locations on the seat pans. I think it's just the height though that's the difference but i'm not sure.
Old Nov 24, 2008 | 11:51 AM
Well for the direct fitment thats a negative... i tried it and the crx seats are narrower. For Hailchristian i am not sure exactly how to do that... do i have to change the back part of the seat or maybe can i get away with just swapping the bottom? thanks
Old Nov 24, 2008 | 03:03 PM
well the bottom of my seats when i was using the integra seat pans at first would not fit right and i just kinda like pushed the seat rails closer together so i could put in the bolts. I got 3 bolt out of 4 to work and it was stable. I swapped seat pans though and now all 4 bolt in. Not sure about with your application.
jason_hann53
Dec 15, 2007 01:18 PM
arneycl
Aug 9, 2007 12:59 PM
kennycivicparts
Mar 1, 2007 05:19 PM
IRVILLEracin98CIVIC
EK Swaps
Aug 9, 2004 07:50 PM
IRVILLEracin98CIVIC
Aug 3, 2004 04:58 AM
