Sensor
Old May 9, 2011 | 05:15 PM
whitecivicex's Avatar
Default Sensor
'96 Civic Ex...D16Y8, trying to determine what the sensor is at the rear of the block, just below the head surface, about midway betweeen the distributor and balancer ends. Single wire to the sensor.
Thank You!
whitecivicex
Old May 9, 2011 | 07:08 PM
droopy128's Avatar
Your temp sensor, send signal to your temperature gauge on your dash.
Correct me if am wrong
Old May 10, 2011 | 05:11 AM
I think the OP is talking about the oil pressure switch. The switch turns on the "oil can" icon light on the dash when the oil pressure is too low. It's above the oil filter and taps into the passage that supplies oil to the head.
There also may be a knock sensor on the back of the block. That will be more toward the cylinder #1 end. It'll have a plastic socket for the single wire. The oil pressure switch just has an exposed pin.
Temperature sender is in the end of the head below the distfibutor.
addiction2bass
Aug 14, 2008 09:53 PM
fglaustin
Mar 27, 2008 08:29 PM
vtec02
May 9, 2007 05:17 AM
00sithrottle
May 12, 2005 10:25 AM
