Sensor Hellp
Old Jun 12, 2008 | 09:25 AM
Christina's Avatar
Default Sensor Hellp
I have a 92 civic with a B16 that i just installed. i am getting a few error codes. 6, 7, 20 ,21. Does any one out there know how to check the sensors with an ohms meter and what values I should be seeing for a good sensor.
Thanks!
Old Jun 12, 2008 | 10:13 AM
mundy5's Avatar
Default RE: Sensor Hellp
Christina,
go to website in my signature and download your service manual. this should help you with those codes.
Old Jun 12, 2008 | 01:27 PM
me262dave's Avatar
I would suggest that you clear the codes first, no point in chasing false codes, ifthey return you willknow its real.
On my 90 civic I pull the hazard fuse in the engine compartment for a minuet, then plug it back in. I do not know if its the same with yours.
You need to download the factory manual as suggested.
I just got one for my car, and there was all kinds of stuff that was left outof chiltons, and haynes. Its the only way to go.
Dave
A "minuet" might be a little long, and not everybody likes classical music, so waiting for a minute would work too.
Old Jun 12, 2008 | 02:05 PM
Yes anytime there is more than one code, need to clear them and see which ones re-occur. On a swap, make sure the wiring harness is wired properly.
Old Jun 12, 2008 | 08:49 PM
Christina's Avatar
Thanks guys!!! Ya they are re-occurring codes. I'm downloading the manual now. I'll keep ya posted on what I find.
Old Jun 18, 2008 | 07:12 AM
Christina's Avatar
Well I found the problem! It was my brother. He must not have reset the computer or disconnected the battery when he installed my V-tec wiring harness. I'm glad it still runs! He also said that he reset the computer after that and rechecked for codes. Well my boyfriend figured it out thank God. Just had to reset the computer and adjust the throttle sensor.
Old Jun 18, 2008 | 07:17 AM
Christina's Avatar
Now it starts normal, idols properly. The CEL doesn't come on when the V-tec kiks in.
Thanks for the help guys and for that super awsom manual!
But one quick question. How do I get code 36 and 20 to go away?
fglaustin
Mar 27, 2008 08:29 PM
vtec02
May 9, 2007 05:17 AM
incecticons forever
Jun 11, 2006 05:51 AM
00sithrottle
May 12, 2005 10:25 AM
