Which shifter bushings to get??
Old Mar 17, 2008 | 03:02 PM
museboy07's Avatar
Default Which shifter bushings to get??
I found two sets on Summit by Energy Suspension. They both have the same exact description but one has a metal sleeve with two small bushings that slip onto it. The other has the bushing as one whole piece. Does it make a difference which one I get? Which one would you get? Thanks!
One with the metal sleeve:
http://store.summitracing.com/partde...p;autoview=sku
One without the sleeve:
Old Mar 17, 2008 | 03:29 PM
civicexracer's Avatar
Default RE: Which shifter bushings to get??
the extension mounting bushings are the same(the pieces that mount to the shifter end) but the extension rod bushings are different(where they mount to the transmission). what year, model, engine, trans do u have?
Old Mar 17, 2008 | 05:07 PM
museboy07's Avatar
I have a 1998 Civic DX 1.6L 5 speed...my shifter has ALOT of slop in all gears...like it feels like its in neutral when its in gear. Which bushings do I get?
Old Mar 17, 2008 | 06:44 PM
the first set, part number 16-1102. check out www.energysuspensionparts.com, its cheaper there.
direct link for ur car
http://www.energysuspensionparts.com...2&cat=1028
MrLizard
Aug 21, 2008 01:53 PM
brunborg
Jan 14, 2008 08:38 AM
fastman90
Transmission and Differential
17
May 1, 2007 11:31 PM
Live_4it
17
Mar 18, 2007 09:22 PM
TrAvIs 05
Jan 15, 2007 05:56 PM
