Shifting into reverse
i've had the same problem for awhile now.
is it the synchros in the transmission?
mine will go into reverse if i shift into 1st, 2nd, 3rd, then reverse.
itll also go in if i lightly push into reverse, then ease off the clutch a bit, and itll slide right in.
its a bit annoying, actually....anyone know how to fix it?
actually i've had some stupid problem with mine as well. i have had two autos before finally getting a manual, but i did learn to drive stick on a couple other cars well before getting mine. i'll throw my civic into reverse...hit the gas a bit, then put it in neutral...a few times i didn't give it enough gas so i go to put it back in reverse with the clutch pedal to the floor. the couple times i've done this (i don't even **** with it now) there was a grinding sound. it confuses the hell out of me since i have the clutch disengaged.
