shims for camber?
Old Aug 7, 2009 | 04:20 PM
kdubbla's Avatar
Default shims for camber?
the guy at les schwabbs said he can just put a couple metal shims in for me to adjust my camber, are these good and reliable and i hear you only add shims if your camber is + and mine is -
my camber: left -1.6 right -0.8
i jsut ordered a camber kit so..... should i cancel it? or is he right?
89 civic HB
Old Aug 7, 2009 | 05:43 PM
for the rear... yes you can just shim the rear upper camber arm. just use some washers and longer bolts.... only problem is its just guess work unless you have the tools to check your own camber...
a camber kit is defiantly the best way to go since your alignment shop can set it up perfect or how ever you want it!
Old Aug 7, 2009 | 05:48 PM
kdubbla's Avatar
Default well
im pretty tight with the guys at les schwabbs, i work in a shop next to them, and he knows the measurements for the size and all and they will check it, so its good? great i dont need a rear camber kit
Old Aug 7, 2009 | 06:04 PM
no you dont need it if your cool that way. just be sure you use the right length bolt... otherwise the bolt will be to short and not enough threads to hold it tight and can wobble out and really cause problems!
just keep putting in afew washers. and after the second time you check it you should be able to guess the extra washers needed or removed. so many washers will change the angle so much. just be sure to have a few different length bolts to be sure you have the perfect length or at least close to...
Old Aug 7, 2009 | 06:14 PM
kdubbla's Avatar
no you dont need it if your cool that way....
i love it when you call me cool
bmelloh
Jul 7, 2009 06:36 PM
sacicons
May 29, 2005 05:19 PM
mr2insane
Mar 1, 2005 01:15 AM
steven87ukuk
Oct 29, 2004 06:32 PM
joeyjoejoe
Jul 11, 2004 07:07 PM
