Aftermarket Cam/Head Help
Old Aug 7, 2009 | 05:05 PM
OaklandT's Avatar
Default Aftermarket Cam/Head Help
I just recently bought a D16Z6,with a stage 2(what I was told,and how it looks) cam.Ive been cleaning the engine up of all the carbon build-up ect ect,and Ive tried turning the head to see if it would rotate.It rotates,but is very hard to turn,and then it gives way,then it gets hard to turn again,then it gives way.Is this normal?! I mainly bout everything just for the tranny,but the 6puck clutch,cam,and cam gear where just perks.
Ive never had a bigger cam,so Im just curious if it should be doing this.Any info would be helpfull.
Old Aug 7, 2009 | 05:07 PM
315 Customs's Avatar
Yes that is the engine building compression then releasing compression. If you remove the spark plugs then try turning the engine again you will find the engine turns much easier.
Old Aug 7, 2009 | 05:48 PM
OaklandT's Avatar
The head is seperated for the block.
Old Aug 7, 2009 | 05:49 PM
OaklandT's Avatar
Bleh im sry its seperated from* the block.Its just sitting on my work bench.
Old Aug 7, 2009 | 05:54 PM
Well in that case then how hard is it to turn? What do you have the head sitting on when you turn the cam? The valves need room to open up.
Old Aug 7, 2009 | 06:12 PM
OaklandT's Avatar
Well in order not to cause any damage to the valves I set the head on its side.Its kinda difficult to turn,but it ends up giving way,then its hard to turn again.I checked to see if something may be jammed,but its clear.I asked the guy I bought it from and he says the reason he gave me the block as well is that it spun a bearing.Im trying to give as much info as possible so if im being a lil vague lemme know lol.
Old Aug 7, 2009 | 06:23 PM
Most aftermarket cams require the use of a dual valve spring kit and if yours has a dual valve spring kit and the valve springs have a high spring rate then it would cause the cam to be tough to turn by hand while its opening valves then easy again while the valves close
Old Aug 7, 2009 | 06:27 PM
darren509's Avatar
I would try checking the valves for a bent one. Also check for clearence on each one.
Old Aug 7, 2009 | 06:57 PM
OaklandT's Avatar
Thx for the help,I hope its not a bent valve,that would be a pain.....
Ill go over it again in the morning
slade8
Dec 6, 2009 06:23 PM
99silverSI
Aug 25, 2007 09:43 PM
civicblend97
Apr 29, 2006 01:12 AM
Pete
Oct 13, 2005 11:32 PM
Dickie
Jan 16, 2005 05:56 PM
