should I replace oil seal
I am bracing myself to do a timing belt and water pump change. This definately exceeds anything I have done before, but I am kind of excited to try it. My question concerns whether I should change the camshaft oil seal. Currently my car does not lose any oil. Advance Auto only had the Felpro seal with a 1 year warranty (so I bought it). I would feel much better, though,if I had a better quality part, but should I go ahead and change it using the Felpro. My thinking is that since the piece is not soft rubber, perhaps the original is still in fine shape, even though it's older. Let me know what you all think. Thanks,
Andy
Andy
I would not replace the seal unless you find it is already leaking. It's easy for even an experienced person like me to mess up a seal putting it in and have to do it all over again.
i replaced both of mine... cam and crank oil seals... its cheap insurance..... just put it on straight with alittle block off wood and tap it in slowly with a hammer little by little...
stupid hcf viruse... i did mine when it was out of the car, but can still be done with the motor in the car.... main thing is take your time, oil or grease the seal up alittle to keep it from tearing when instaling.
i just pulled the old seal out with a small screw driver enough to pull the seal out and clean any dirt or gunk out from the seal housing,
just like any oil leak high in the motor. it will always be leaking alittle while the motor is running. and besides the ugly oil all over and spots it leaves where you park, the oil can also make the timing belt fail/break down alot faster than a dry belt would.
oil is only good where its needed not good where its not needed for moving parts and IMO buy OEM seal for the perfect fit and best quality! if i remember corectly it was like 5-15bucks brand new.
