Simple Rear Suspension Question
Old Apr 3, 2008 | 08:47 AM
aeromang's Avatar
Default Simple Rear Suspension Question
Simple for everyone else.
I'm going to replace my rear shocks and coils since they are over 10 years old (1998 Civic LX). My question is:
Do i have to get the rear wheels aligned after installing the new shocks/coils?
Or does that only need to be done with control arms??
Old Apr 3, 2008 | 09:07 AM
Default RE: Simple Rear Suspension Question
If you're lowering the car, alignment should be checked. When you're just replacing stock for stock that would be no problem. Unless something is wrong with the spring itself (broken or sagging), it can be reused on a new strut.
Old Apr 3, 2008 | 09:12 AM
aeromang's Avatar
Thanks, thats one of the reason's i'm replacing them. The shocks are old, but the left spring is shorter or sagging and has been for 3 years.
So can i keep the right spring and just replace the left spring and both shocks?
Do i need an alignment then? Since the spring has been sagging for so long.
Old Apr 3, 2008 | 09:34 AM
mxs's Avatar
mxs
You should get an alignment every couple of years anyway.
Old Apr 3, 2008 | 09:37 AM
aeromang's Avatar
Thanks for the help, this is my fist time using one of these forums.
Tater
Feb 10, 2007 11:23 AM
Rickimaru
Oct 11, 2006 09:28 AM
01exfourdoorsaloon
Sep 14, 2006 11:47 AM
1slowdx
Jan 8, 2006 08:03 PM
Zero Knights
Feb 24, 2005 10:49 AM
