SKUNK 2 INTAKE MANIFOLD
Yes. All stock parts will fit on there. You dont need to upgrade the injectors if youre just putting an aftermarket intake manifold on. I also think an aftermarket larger throttle body is a waste of cash, because theyre so expensive. Just have the stock one bored out at a machining shop.....if you cant hold up for down time, then buy a used stocker online, and bore that out, then swap em out. I had a turbo D16z6 with a skunk2 intake manifold, stock throttle body, not bored and it was fine. Now I have a Gsr swap and a skunk2, stock throttle body. The aftermarkets are too much $$.
