Smell of fuel when starting up cold or warm
Hi all, just a quickie question, when i start the car i smell fuell, but it only lasts for a small while then dissapears ???? any ideas as to why you get a smell of fuel when starting up.....its a Civic 93 ESI auto just in case D16Z6 i think ?
thanks all
Spevie
thanks all
Spevie
All I can think of is a fuel leak somewhere inside the engine bay. As the engine heats up, it evaporates the leaking gas, and you smell it. But that wouldn't explain the smell going away part unless it was a really slow leak...
Hi there, how do i check the vapour recovery system, didnt even know there was such a thing.?
PS, wats a cat back exhaust system ?????? i need to replace my back box but if the whole exhaust is on its last legs then will get a good performance enhancing one but just wondered what a cat back system was.....?
Thanks
Thanks
This is testing that the vapor recovery systems, including parts like the charcoal canister and fuel tank vent, are functioning correctly. This system is supposed to prevent unburned gasoline fumes from exiting your car. Basic visual inspections including fresh air inlet of charcoal canister.
Chopin
May 14, 2013 04:29 AM
exnihiloman66
12
Apr 26, 2010 04:30 PM
kjreinha
Mar 31, 2006 11:07 AM
tanksOnFire
Jan 8, 2005 03:38 PM
tanksOnFire
