Smoke on cold start
Here's the thing: the car has been knocking when cold (but only in the fall/winter) and occasionally burning oil right when I start it up for the first time every day or every other day. Well, I'm on vacation so its been a few days since I drove it. Today it smoked for at least a minute and a half while I was sitting there parked. I'm totally sure it's oil too.
How do I find out if its the valve seals or the piston rings? Stu and I think it's valve seals because the smoking goes away once the engine runs for a bit. The cold start knock also goes away once the thing warms up.
It has knocked like this for about 10K miles, only on cold start, and has occasionally smoked like this for the past 7K. Prognosis?
Mine was like that. Valve seals were a waste of money. It was the rings. If it smokes worse when you floor it, it's the rings.
You can probably get rid of the knocking by adjusting the valves. Civic engines don't have hydraulic lifters, they have screws that need periodic adjustment. It's not related to the smoking.
The knock is a rod bearing. Bottom end for sure. Just had a valve adjustment 12K ago. Definitely not a valve tap. It DID smoke when I accelerated on the highway, 4 to 3, then accidentally to 2, revved to 5K, SMOKED, then cleared. But only once. I did that again and it didnt smoke a second time.
Dwillis
May 2, 2015 10:19 AM
David_S
Oct 24, 2013 10:06 AM
general23cmp
Dec 20, 2008 10:43 PM
thesteveman
Feb 10, 2005 01:07 AM
