Speedo
Old Aug 24, 2007 | 05:49 PM
Todd's Avatar
Default Speedo
I want to change my gauge cluster, I do not have a tach and I would like to add one. I have found an SI gauge cluster but it is from a 92 to95 style, my civic is an 1999 LX. Will this fit and will the tech work. thanks for your help
Old Aug 24, 2007 | 06:00 PM
classiccarsrule85's Avatar
Default RE: Speedo
well it would work if you chopped up the wire harness i found a website with all the wires and stuff.....its for a integra into a civic but if you follow the directions it would be good......however id suggest buying a small tach and one of those pod things for your cluster surround and do it that way and just hook it up as such be a lot easier and it woudl look cooler not to mention you could make money off of hte si cluster and cut down your cost on this job. Of getting a tack put in.
http://honda-tech.com/zerothread?cmd...amp;id=1053318 --guage cluster swap
Guage pod thing
http://cgi.ebay.com/ebaymotors/96-97...QQcmdZViewItem
Old Aug 24, 2007 | 06:01 PM
Sigracer10's Avatar
Default RE: Speedo
i know that the wiring can be done, but yes you will have to switch around wires, but i don't know if the cluster itself fits. but if you can find a 96-00 cluster with a tach, its just plug and play, i have an ex cluster in my cx and it works great
iamurDJ
Apr 9, 2006 05:38 PM
derekdunham
Nov 20, 2005 10:30 AM
ashbar
Aug 4, 2005 10:20 AM
derekdunham
Jul 25, 2005 10:39 AM
nigel_miguel
Jul 6, 2005 09:38 PM
