HondaCivicForum.com
-   -   speedo working sometimes (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/speedo-working-sometimes-92535/)
98hatchem Mar 12, 2012 09:40 AM
98 civic hatch dx
speedo doesnt want to work when i first drive the car. after about 5 minutes it starts to work. all other gauges in the cluster are operational. anyone else having this problem.
im guessing its the speed sensor. anyone one know where its located?
anyone else have this problem?
98hatchem Mar 12, 2012 10:39 AM
i should add that the odometer doesnt work also when the speedo isnt working. it seems to be correlating with the temp of the motor. cold motor speedo and odometer doesnt work, warm motor they both work.
cvcrcr99 Mar 12, 2012 10:56 AM
Odometer and speedo not working at the same time out of no where would prove to be a VSS issue. Do you get a CEL for the VSS once it quits working?
98hatchem Mar 12, 2012 11:36 AM
well i just purchased the car from my boss. and the cat was removed years ago, so the cel is on for that.
is there anyway i can take a volt meter to the sensor to see if its working?
