Speedometer/odometer cuts in/out, 98 EX coupe
I have a 98 EX coupe that has a speedometer that cuts in and out, very random. Interestingy, typically it will work if I start the car with the cruise control on (but not always). Two other things that may be related: the cruise control "on" light does not work at all, as well as the keyless entry no longer functions (and can't be reprogrammed).
I suspect these are all related. Maybe a bad ground somewhere? Anyone have any thoughts on how to sleuth this one? Thanks! |
1) Since both the speedometer and odometer don't work sporadically, then the Vehicle Speed Sensor (VSS) atop the transmission is probably bad. Also inspect the VSS connector. Is the CEL ON?
2) Does the cruise control function? Is the light in button or the gauge cluster not working? 3) If the power locks work but not with the keyless remote, then check the remote battery and remote itself. Also check for blown fuses (e.g., fuses 14, 28, and 47). |
Hi Ron. Thanks for the tips. Here's to fill in your questions:
CEL is not on. Cruise Control works fine...just the light on the button itself doesn't come on (the dash light works). Power locks work, and I've changed the battery on both keyless remotes I have. Just can't reprogram the remotes through the radio and get the keyless to function (or the panic button). All fuses both under dash and under hood seem OK. Did notice that in the wiring diagram somehow the cruise control is linked to the radio for the keyless entry. Seems like some sort of electrical connection/ground issue somewhere to me... Too many coincidences. |
Originally Posted by BillStuart
(Post 609229)
CEL is not on.
Cruise Control works fine... ...just the light on the button itself doesn't come on (the dash light works). Power locks work, and I've changed the battery on both keyless remotes I have. Just can't reprogram the remotes through the radio and get the keyless to function (or the panic button). All fuses both under dash and under hood seem OK. Did notice that in the wiring diagram somehow the cruise control is linked to the radio for the keyless entry. Seems like some sort of electrical connection/ground issue somewhere to me... Too many coincidences. |
Hi Ron. Thanks for your tips and great info. You know, I'm actually not sure I tried using the Cruise when the Speedometer/Odometer weren't working. Since you say they are both linked to a functioning VSS, then if the Cruise does work when the other does not, that would be telling. I'll check it out and let you know. Btw, when the Speed/Odo work, it's rock-solid with no flutter
I'll also investigate the Cruise bulb. Seems odd for that to blow to me, but one never knows. I have previously downloaded the shop manual, and tried reprogramming the keyless operation several times. As well as followed the directions in the owner's manual. No luck. It's in the shop manual where I noticed the link between the keyless entry and the cruise control somehow. The radio itself works fine, but it appears the keyless operation is on a separate circuit from this. Also...low fuel light doesn't work. I assume not related, but who the hell knows. I'll also check the VSS connector. Thanks again. |
(Post 609300)
2 Attachment(s)
(Post 609300)
Attachment 23345 Attachment 23346 |
To get to the sending unit and the green/yellow wire for Ron's test, take the bottom cushion of the back seat out of the car. This is done by reaching through the gap between the cushions slightly left of center and removing the bolt. Then pull the back part of the bottom cushion up and tilt the cushion forward to unhook it at the front.
Now you can see the wires going to the fuel tank. Remove the metal plate and you are looking at the top of the tank and its fittings. |
| All times are GMT -8. The time now is 03:33 AM. |
